Hi,
I have an issue with the store locator widget. Once I embed it in Hostinger, it’s impossible to resize the widget itself.
Can someone please help me?
Here’s a screenshot.
Hi there and welcome to the Community, @Anik_Dessureault ![]()
This issue occurs because of the Hostinger iframes. To fix it, you should reinstall the widget avoiding iframe.
For this, please replace your current widget’s installation code with the new one:
<script src="https://custom-scripts.elfsightcdn.com/public-scripts/hostinger-and-go-daddy/install-widget.js" data-banner></script>
<div class="elfsight-app-WIDGET_ID"></div>
In this code you should replace WIDGET_ID with the ID of your widget. Please try it out and let me know if it helped ![]()
