Store Locator Photo Customization
Hello,
I would like to change the object-fit of the image in the Detailed Card at the top, from ‘cover’ to ‘contain’, will you please help me?
Thank you :slight_smile:
Happy to see you on our forum! Welcome @Foulianna_FouaGraf :wave:
Here is the code we’ve added to the Custom CSS field on the Style tab of your widget’settings:
global-styles,
[class*="Preview__Container-sc"] [class*="MediaImage__Container-sc"] img {
  object-fit: contain !important;
Check your widget and let me know if you like the result :wink:
Thank you so much!
Actually it works and it’s exactly what I was looking for, but when I embed the script in my website (via HTML Elementor widget) it’s not working (I mean the custom CSS has no impact).
Do you have any idea why this is happening?
Could you please share a link to the page where your widget is installed? I’ll be happy to look into this for you :slightly_smiling_face:
Thank you so much for your help, I appreciate it!
Apparently, I deleted the script, updated the page, and re-pasted it in the HTML widget.
Now it works just fine! Probably some Elementor conflict?!
Anyway, I’m good for now, thank you again! :slight_smile:
I’m also trying to change the marker on the map to be another color if selected, so it will be more obvious (currently it only changes its size slightly).
If I may suggest, it could take color from the Accent, to be easily customisable.
Here is the CSS I use but it doesn’t work:
global-styles,
[class*=“elfsight_map”] [class*=“marker__Container-sc”].active svg path {
fill: black !important;
I could use your advice, thank you! :slight_smile:
Hi @Foulianna_FouaGraf :wave:
Got it! I’ll discuss with our devs if it’s feasible and will get back to you a bit later :slightly_smiling_face:
We’ve added this code to the widget:
.global-styles,
[class*="elfsight_map"].active [class*="marker__Container-sc"] svg path {
Please check it out and let me know if you like the result :slightly_smiling_face:
It works, thank you so much!!!
It was a silly mistake of mine, I guess I’m still learning!
I really appreciate your help!
Still, if I may suggest, it would be awesome for the store locator app to have an option to select different color for the active location, I believe many users would like to use it without custom CSS, so please consider this suggestion as a ‘user testing feedback’.
Thank you again! :slight_smile:
Glad to hear that the solution worked :wink:
I agree that it would be helpful to have such an option in the editor and I’ve added your idea to the Wishlist. You can keep tabs on it here - Option to change the color of the cohose marker
