Change side panel width
It would be great to be able to change the size of the side panel or to be able to hide it, on small sizes it covers a lot of the card which is the main element.
Thank you.
Hi @Benjamin15 :wave:
We agree that it would be awesome to have this setting in the configurator. We’ll try to think this opportunity over in the future updates :slightly_smiling_face:
As for now, you can adjust the side panel’s appearance using these codes:
  1. Hide panel and floating reopen button on mobile devices:
@media screen and (max-width: 819px) {
[class*="desktop-layout__Sidebar-sc-"],
[class*="mobile-layout__Directory-sc-"],
[class*="FloatingButton__FloatingButtonContainer-sc"]{
		display: none !important;
  1. Here is the code to adjust panel’s width on mobile:
	[class*='directory-locations-list__Container-sc'] {
		width: 300px !important;;
If you want to apply these changes for the desktop version too, just remove the 1st line in each of the code.
Note: The codes should be added to the Custom CSS field on the Style tab of your widget’s settings
