Width on Mobile and desktop
add the option to configure the width and the mobile screen differently
Hi there, @backhome84 :wave:
You can control the width on mobile using the Padding on Mobile setting:
Does this option work for you?
the width control is functioning differently
Got you!
I’ve added your idea back to the Wishlist and if it gets more votes, we’ll try to think about it :slightly_smiling_face:
