Store locator map information issue
Hello,
I have an issue with the store locator widget. When I edit it from Elfsight dashboard, everything is fine. Once I embed it in elementor, some of the map informations (like roads number, street names) are not displayed.
Can someone please help me on this matter ?
Here are a screenshot showing the differences:
Thank you.
Hi @Guillaume1 :wave:
Please send me a link to the page, where your widget is installed. I’ll be happy to check it for you :slightly_smiling_face:
Hi,
Thank you for answering.
You can find the page here :
https://maison-millet.com/nos-boulangeries/
Thanks!
I’ve forwarded this issue to the devs and will update you once any news comes up :slightly_smiling_face:
Thank you very much.
Do you or the devs need access to the page ?
As the site is still in development, we would prefer to keep it unvailable.
No, you can unpublish it :slightly_smiling_face:
By the way, devs found that if you switch the Map Color Scheme to Classic, everything will work fine. So, you can use this workaround, while we’re working on the fix.
Alright I will wait for your comeback.
By the way when switching to classic theme, the map shows indeed more informations (roads and shops), but still lacks some like streets, and neirby towns, etc…
Thank you !
Hi there, @Guillaume1 :wave:
The issue is fixed! Please check your widget and let me know how it works :wink:
Hello,
I just checked, it works perfectly !
Thank you very much !
Great, you’re welcome :wink:
