Stop auto saving in widgets
When you edit a widget you get two options to close out.
Close - auto saves any work that you did.
Publish - current state of work
I have an active widget, but now that active design is lost after few changes and auto saving.
There needs to be third option of saving current design otherwise close would revert to the design when it was opened.
Hi there @Rive_Social :wave:
I do see your point, and I’m very sorry that there is no 3rd option for such cases in the configurator. We will try to think this opportunity over and hopefully, we’ll be able to implement it in one of the future updates.
We’ll keep you posted here :slightly_smiling_face:
