To add timeline with alternate layout: image, text, description, vertical line, fade in fade out effect, like this.
- view demo – password: abc
#1.1. First add Section > Choose Team > Choose Section with (i) icon
#1.2. Hover on top right of section > Click EDIT CONTENT
#1.3. at Design > Choose Simple List
#1.4. at Elements > Enable: Section Title, Item Title, Body, Image
#1.5. at Content > Add your desired title text, image
#1.6. Hover on top right of section > Click EDIT SECTION
#1.7. at Format > Anchor Link, enter word: timeline-07
#1.8. Hover on Page where you use Team section > Click Gear icon
#1.9. Click Advanced > Paste this code
- If you use Personal/Basic Plan and your plan doesn’t support Injection, see #3.1
<!-- 07.26c04v1 Timeline 07 -->
<style>
body:not(.sqs-edit-mode-active) section[id*="timeline-07"] .user-items-list{display:none!important}
body.sqs-edit-mode-active .tl07-wrap {display: none !important;}
</style>
window.Timeline07Config = {
sectionId: 'timeline-07',
maxWidth: 700,
containerPadding: 80,
fixedBackground: true,
changeBackground: true,
overlayColor: 'rgba(58,58,58,0.82)',
headerColor: '#ffffff',
titleColor: '#ffffff',
descColor: 'rgba(255,255,255,0.72)',
lineColor: 'rgba(255,255,255,0.14)',
inactiveOpacity: 0.25,
inactiveBlur: 3,
sideLabel: 'FATHER OF THE TURKS'
<script src="https://code.beaverhero.com/list/0726c04v1timeline07.js"></script>
#2.1. To change text color, you can change Line 14 to Line 16
#2.2. To change overlay color, change Line 13
#2.3. To change vertical line color, change Line 17
#2.4. To change this text
You can change Line 20
#3.1. If you use Personal/Basic Plan and your plan doesn’t support Injection, you can edit current page (page where you use Team section) > Add a Markdown Block
Add this code into Markdown
<style>
</style>
maxWidth: 700,
inactiveBlur: 3,
