Here we will use custom code to sort blog post in alphabetical order, however if you aren’t familiar with code, you can use this plugin (follow step #2 in this thread to use plugin) instead.
You can add code to Code Injection > Footer.
let allSortedPosts = [];
let postsPerPage = 20;
async function getAllPostsSorted() {
try {
const currentPath = window.location.pathname;
const collectionUrl = currentPath.endsWith('/') ? currentPath.slice(0, -1) : currentPath;
let allPosts = [];
let offset = null;
let hasMore = true;
while (hasMore) {
const url = offset
? `${collectionUrl}?format=json&offset=${offset}`
: `${collectionUrl}?format=json`;
const response = await fetch(url);
const data = await response.json();
if (data.items && data.items.length > 0) {
allPosts = allPosts.concat(data.items);
if (data.pagination && data.pagination.nextPageOffset) {
offset = data.pagination.nextPageOffset;
} else {
hasMore = false;
} else {
hasMore = false;
allPosts.sort((a, b) => {
return a.title.toLowerCase().localeCompare(b.title.toLowerCase());
allSortedPosts = allPosts;
return allPosts;
} catch (error) {
console.error('Error fetching posts:', error);
return [];
function displayPage(pageNumber = 1) {
if (allSortedPosts.length === 0) {
return;
const startIndex = (pageNumber - 1) * postsPerPage;
const endIndex = startIndex + postsPerPage;
const postsToShow = allSortedPosts.slice(startIndex, endIndex);
const container = document.querySelector('.blog-basic-grid');
const pagination = document.querySelector('.blog-list-pagination');
document.querySelectorAll('.blog-basic-grid--container').forEach(article => {
article.remove();
postsToShow.forEach((post) => {
const publishDate = new Date(post.publishOn).toLocaleDateString('en-US', {
month: '2-digit',
day: '2-digit',
year: '2-digit'
const article = document.createElement('article');
article.className = 'blog-basic-grid--container entry blog-item is-loaded';
article.innerHTML = `
<div>
<a href="${post.fullUrl}" class="image-wrapper">
<img src="${post.assetUrl || ''}" alt="${post.title}" class="image"
style="display:block;position: absolute; height: 100%; width: 100%; object-fit: cover;">
</a>
</div>
<div class="blog-article-spacer"></div>
<div class="blog-basic-grid--text">
<div class="blog-meta-section">
<span class="blog-meta-primary">
<span class="blog-author">${post.author ? post.author.displayName : 'Admin'}</span>
<time class="blog-date">${publishDate}</time>
</span>
<span class="blog-meta-delimiter"></span>
<span class="blog-meta-secondary">
</span>
</div>
<h1 class="blog-title">
<a href="${post.fullUrl}">${post.title}</a>
</h1>
<div class="blog-excerpt">
<div class="blog-excerpt-wrapper">
<p>${post.excerpt || 'No excerpt available'}</p>
</div>
</div>
<a class="blog-more-link" href="${post.fullUrl}">Read More</a>
</div>
container.insertBefore(article, pagination);
updatePagination(pageNumber);
function updatePagination(currentPage) {
const totalPages = Math.ceil(allSortedPosts.length / postsPerPage);
if (!pagination) return;
const newer = pagination.querySelector('.newer');
const older = pagination.querySelector('.older');
newer.innerHTML = '';
older.innerHTML = '';
if (currentPage > 1) {
newer.innerHTML = `
<a href="#" onclick="displayPage(${currentPage - 1}); return false;" rel="prev">
<span class="prev-label">Newer Posts</span>
</a>
if (currentPage < totalPages) {
older.innerHTML = `
<a href="#" onclick="displayPage(${currentPage + 1}); return false;" rel="next">
<span class="next-label">Older Posts</span>
</a>
async function initSortedBlog() {
await getAllPostsSorted();
displayPage(1);
initSortedBlog();
