To make Newsletter Popup appear when users click text in a paragraph, you can follow these.
#1. First, create a Page in Not Linked.
With Name/URL: Content Lightbox β /content-lightbox
#2 . Edit Content Lightbox page > Add 3 Newsletter Blocks > Then find ID of 3 Newsletter
In my example, we will have:
- Newsletter 1: #block-yui_3_17_2_1_1740272913615_4410
- Newsletter 2: #block-f28463982ccaf58fe3ce
- Newsletter 3: #block-a4d22459b6c0380c248d
#3. Edit Paragraph where you want to make Newsletter Popup appear > Edit 3 Texts > Add URL > Use this URL format.
Make sure βOpen in New Tabβ is disabled
Text 1: #wm-popup=/content-lightbox#block-yui_3_17_2_1_1740272913615_4410
Text 2: #wm-popup=/content-lightbox#block-f28463982ccaf58fe3ce
Text 3: #wm-popup=/content-lightbox#block-a4d22459b6c0380c248d
#4. Install Popup Plugin
and Footer
#5. Result
When users click text 1 >> Newsletter Popup 1 will appear
When users click text 2 >> Newsletter Popup 2 will appear
When users click text 3 >> Newsletter Popup 3 will appear
