Show specific reviews first (pin reviews)
Instead of a filter to ONLY show reviews that match the filter, I’d like a feature to simply show these reviews first and then other reviews that don’t match the filter after.
In some cases there are only one or two reviews that match a filter and I’d really like to show these first, but not exclusively.
Welcome aboard @Ethan_Martin :wave:
Nice suggestion, thanks! We’ll have it in mind and I’ll update you here in case of any news :slightly_smiling_face:
Yes please!!! I have some review that are really good that should be sorted first. Ideally if we can bundle those reviews as “pinned” and be able to randomize through the pinned ones as well
Really would need that too! :slight_smile:
Status Update: the feature moved to the Design stage! :tada:
We’ll keep you posted on the further progress :slight_smile:
Quick update: the feature moved to the Development ! :tada:
Hey everyone!
We are happy to share that now you can pin specific reviews:
Find more details and share your feedback in this post - Reviews: Enjoy enhanced review managing and pin specific reviews feature
