Pin review
All in one reviews - you can select list review by age and list by stars can we also have added to the list that we can select a default post for each media outlet to show as the first post please this would allow us to specify a post that is very positive to your business to show at the top. Thx
Hi there, @Ian_Reed :waving_hand:
Many thanks for the feedback!
Unfortunately, there is no way to feature a specific review now. However, this idea sounds great and if more users upvote it, we’ll try to consider it in the future updates :slightly_smiling_face:
Status Update: the feature moved to the Design stage! :tada:
We’ll keep you posted on the further progress :slight_smile:
Quick update: the feature moved to the Development ! :tada:
Hey everyone!
Great news – now you can pin specific reviews to top :tada:
