Show a scroll bar for more posts
This is my first question and I hope to find an answer here.
I use elfsight for our LinkedIn posts hand have 12 showing with 3 in one line. When the “Load More” button is pressed on the live-site, I see the next three slightly cut-off and cannot go down any further (not sure how to add you a screenshot, sorry). Our site is: https://www.rnrpartners.ch/insights-r-r-value-partners
I could of course have a huge white space available at the bottom of the page but that would look not very nice.
Is there a way to display a scroll bar so people can scroll down to more posts? It works just fine on mobile but not desktop.
Thank you very much.
Welcome to the Community, @MonikaR :waving_hand:
The issue appears because of the Wix iframes. To fix the issue, please reinstall the widget avoiding iframes using one of the following methods:
If you face difficulties with it, please request the widget installation in your dashboard and our Support Team will gladly assist you with it. Do not forget to mention that the widget should be installed avoiding iframes :slightly_smiling_face:
