Scroll bars appear when Load More button is clicked
  • Issue description:
    Hello,
I’ve added the Instagram Feed app to my WIX website using an HTML box. However, when I click the “Load More” button, the additional posts load with scroll bars inside the box rather than expanding the page downward. On mobile, while the scroll bar doesn’t appear, the experience still feels awkward, as if there are two scroll bars on the screen.
Could you please advise if there’s a solution to make the feed expand smoothly without the internal scroll bars?
Thank you in advance for your help!
(Updated Link)
Hi @Aiden.Y, thanks a lot for all the details provided!
To fix the issue, please try to reinstall the widget outside of the iframe, this article will help you do so: Installing Elfsight widget on Wix avoiding iFrame - Elfsight Help Center
Let me know if it helped :slight_smile:
Hi Helga,
Thank you so much for your help! Everything is working perfectly now, and the installation turned out to be much easier than I initially thought.
I appreciate your support!
Awesome, thanks for the update! We’re always happy to help, so feel free to contact us here in case of other questions :smiling_face:
