I would like to suggest a feature for the AI Chatbot widget that would make it possible to control when the chatbot button becomes visible on a website.
For example, it would be very useful to have options such as:
Show the chatbot only after a specific delay, for example after 10, 15, or 20 seconds.
Show the chatbot only after the visitor has scrolled a certain number of pixels.
Apply these visibility settings separately for desktop, tablet, and mobile devices.
Sure, to clarify: in my situation, I am mainly referring to the round chat button/bubble.
I would like this button to become visible only after specific visibility settings are met, such as a delay or after scrolling. Until that moment, nothing from the widget should be visible on the website.
The reason for this request is that on mobile devices, the chat bubble currently overlaps important CTA buttons on certain Google Ads landing pages. That means visitors see the chatbot button immediately when the page loads, sometimes directly on top of the main conversion button.
That is why it would be very helpful to have settings that prevent the chat bubble from appearing immediately on page load, especially on mobile.
Although the widget doesn’t offer such visibility settings, I think it’s possible to implement via custom script.
I see that you have 2 AI Chatbot widgets. Could you please specify the widget name and the trigger(s) you’d like to use there? Our devs will be happy to help with the customization
This script should be added to the Custom JS field on the Settings tab of your widget settings. The delay time is set in milliseconds and you can change it here:
