Create Auto Hide Feature
Hi Max, it will be nice if the AI chat has an autohide feature to make the chat window disapear after specific time if the user did not engage in a conversation with the chat bot
Cool idea, thanks for sharing @backhome84 :+1:
Hi there, @backhome84 :wave:
Here is a solution from our dev team that should be added to the Custom JS field on the General tab of your widget’s settings:
const TIMEOUT = 30;
function waitForElement(selector, root = document) {
    return new Promise((res) => {
        let i = 0;
        function check() {
            if (component) {
                res(component);
            } else if (i !== 50) {
                setTimeout(check, 100);
                i++;
        check();
waitForElement("[class*='eapps-ai-chatbot'] button").then((bubble) => {
    const portal = bubble.parentNode.parentNode;
    const closeChat = () => {
        const window = portal.querySelector("[class*='window-transition__Container-sc']");
        if (window) {
            bubble?.click();
    let closeChatInterval = setInterval(closeChat, TIMEOUT * 1000);
    const resetInterval = () => {
        clearInterval(closeChatInterval);
    document.addEventListener("visibilitychange", resetInterval);
    document.addEventListener("click", ({ target }) => {
        if (target.closest("[class*='window-transition__Container-sc']")) {
            resetInterval();
    document.addEventListener("keydown", ({ target }) => {
        if (target.closest("#interactionInput")) {
            resetInterval();
In the 1st line you should set the period of inactivity (in secs), after which the chat will be closed :slightly_smiling_face:
