Search bar for text blocks
Dear Staff, The ai chatbot widget is great, but I would like to recommend more training. As for the text blocks, I would like to have a search bar because I have a lot of blocks. If I want to edit information I had to scroll and find it, which took a long time. Hope admin will consider it. Thank you.
Hi there, @Narakorn_GOT.N :wave:
The idea of adding the search bar for the text blocks sounds reasonable. I’ve moved this idea to the Wishlist and if it gets more votes, we’ll try to consider it in the future.
As for more training, could you please elaborate on what you mean?
Friends, I’m happy to say that we’ve started working on this feature! :tada:
It’s currently in the Design stage, and we’ll keep you updated on the progress here :blush:
Update: the feature moved to the development :tada:
Hey everyone!
We’re happy to share that the search option has been added to the knowledge base :rocket:
Check this post for more details AI Chatbot: Find the Info You Need Faster with New Knowledge Base Search
