Salesforce integration
Salesforce integration is needed to make the data transfer more efficient. Thanks.
@user12 I agree that Salesforce integration would add more value to the app, thanks a lot for sharing your idea!
You know, we’re on the verge of releasing Zapier integration, could this one be a solution for your case? If so, you can follow the updated regarding this option here :slight_smile:
Thanks a lot for helping us!
Hi @user12, just a quick update!
I’m happy to say that Zapier integration has just been added to the Form Builder app :slight_smile:
Just in case, here’s the link with some more info: Forms, Popup, Banner: Zapier integration
To have the information someone fills out be put in salesforce
Hey there, @user22058 :waving_hand:
Thanks a lot for sharing your thoughts!
The Salesforce integration request is already on the Wishlist and I’ve added your comment there too. If this idea gains more votes, we’ll try to think about it in the future :slightly_smiling_face:
