Can someone help me with using this system? I tried to load my FB reviews but didn’t have luck on my website.
Hello @user2479 and welcome to Elfsight Community!
I am terribly sorry about all the inconvenience caused!
At the moment, our Reviews widgets are experiencing some temporary issues. You can find more details in this topic
I’ve forwarded your request to our devs, and, hopefully, they’ll come up with a solution really soon.
Please do not worry, I’ll keep you updated!
Thank you for your patience and understanding
Hello @user2479!
The issue is fixed!
Just to share, not all reviews were returned because you are using the blocks parameter, which filters the reviews based on “most recent.”
Even though more reviews are available, Facebook limits the reviews filtered to the most recommended ones. You can remove the blocks parameter if you want all the reviews to return.
I hope this explains things.
Could you please check the widget and let me know how it works for you?
