Wish to display your floating Reviews badge on each page load even if a user closed it? This script will do the trick:
localStorage.removeItem('Reviews.closed-elfsight-floating-badge.WIDGET_ID');
Replace WIDGET_ID with the ID of your widget and add the resulted code to the Custom JS field on the Style tab of your widget’s settings ![]()
Guys, was this solution helpful to you? Feel free to share your experience in the comments
