Return to default language
A nice option would be to have the ability to revert to the website’s default language. I have English and German as languages ​​in the widget. My default language is Dutch. If I add Dutch to the widget and, for example, select German first, the widget translates the website from German to Dutch, which produces strange results. It would be nice if you could add a language that is the default language and have that language use the base website without translation.
Hello there,
The default website language should automatically appear in the widget upon installation. I’ve checked your website and see that it doesn’t have any default language:
Please set the default language for your website ( lang="nl") and you should be fine :slightly_smiling_face:
