Set by default language setting
Hi there, @Godwin and welcome to the Community :waving_hand:
The widget identifies your website’s language and uses it as a default language. Does this work for you?
If you need a language different from your website’s language, to be default, please describe your use case in more detail and share a link to the page, where your widget is installed :slightly_smiling_face:
