Issue description:
On mobile, the layout causes the menu descriptions, especially those with bullet points, to be difficult to read. For mobile only: Could we possibly make the image section smaller and the description section larger? Also, can we remove the indent on the bullet points to enhance readability? -
Temple City — The Dive Oyster Bar
Food → Entrees
Hi there and welcome to the Community, @Sebin_Sohn ![]()
I’ve relayed your request to the devs. Currently, they are out of the office, so I’ll get back to you on Monday ![]()
Hi @Sebin_Sohn ![]()
Here is the solution from our devs:
.global-styles,
[class*="Description__DescriptionComponent-sc-"] ul,
[class*="Popup__Description-sc-"] ul {
padding: 0;
padding-left: 1em;
@media(max-width: 600px) {
[class*="RestaurantMenu__Component-sc-"]
[class*="Image__ImageComponentContainer-sc-"] {
width: 50px;
height: 50px;
[class*="RestaurantMenu__Component-sc-"] {
padding: 0;
Add this code to the Custom CSS field on the Style tab of your widget’s settings and let me know if you like the result ![]()
This works perfectly. Thank you very much! ![]()
Great! You are most welcome ![]()
