Repeat not working right
I have a few things on a custom repeat for 3 days, and some are repeating, some aren’t, and one is showing up on day one and day 3, but not day 2…
Anything I can do to make this feature work as expected?
Hi there, @Matt_Golden :waving_hand:
I see that you’ve set the following repetition: Daily, every 3 days:
With this setting, the 2nd repetition will occur in 3 days after the first one, but not 3 days in a row.
For example, the 1st repetition of the Bangri-La Boutique event is on June 19, and the next will be in 3 days (June 22)
I hope this explains things.
If you want to repeat an event 3 days in a row and then finish it, you should set it this way :slightly_smiling_face:
You are right! USER ERROR on me.
