Recurring events showing as individual events in grid/carousel layout
I’d like to have recurring events displayed in a Grid or Carousel layout, but I don’t want each occurrence of the recurring event to appear as a separate card. Is there a way to configure the Events Calendar so recurring events are consolidated into a single event/card in the Grid or Carousel layouts & the date automatically updates after the previous date has passed?
Hi there, @Logan_Carroll :waving_hand:
There is no settings in the configurator or CSS code for this case, but we can manually adjust the number of the repeated event cards displayed.
I see that you have 2 Event Calendar widgets. Would you like to adjust this number in both widgets?
So sorry for the incredibly delayed response. I would like for this too apply to the:
• 'PrimeLife (55+) - EVERY Thursday indefinitely
• The Grace Course (Freedom in Christ Ministries) - once a week; 6 week course
• Women’s Bible Study: Promises Kept - once a week, 6 week course
Those events are not currently listed as recurring events, but once we apply the CSS rule, I’d like to change that.
Done! The changes will be reflected in the configurator and to make it work on your website, click on the Publish button at the top right corner.
Check it out and let me know if you like the result :wink:
Love it. Thank you for your help, Max. We’re testing next week to see if the date resets on its own.
