Radio Widget is not working properly.
Hi and welcome to the forum! ![]()
I’m sorry that you have difficulties with our Radio Player widget, and I’ll be happy to help!
I’ve checked your widget, and it seems you’ve added a link to the stream, and I’m afraid this is the reason it doesn’t play.
We have an article that explains how to get the link that is required for the Radio Player, please have a look: Why my radio station link doesn't play in Radio Player - Elfsight Help Center.
Please let me know if it helped ![]()
Hello,
Thanks for getting back to me. I just want to inform you that it was okay till yesterday. But from today it is not working.
Please fix this problem.
Hi, thanks for your reply!
We’ve checked things and found the issue with CORS that prevents the widget from playing:
To fix it, you should replace your http current link to the https link, and you will be good.
You can find instructions on how to do it in our article: Why my radio station link doesn't play in Radio Player - Elfsight Help Center.
Please let me know if it helped!
