Question about number of widgets on Basic plan
Hi,
Is it possible to create 3 different widgets (e.g. spinning wheel, sales notification, radio player) with the ‘BASIC’ plan?
Waiting for your answer
Bestdm
Greetings and welcome to the Elfsight Community, @user4548 :waving_hand:
Just to clarify — the term app refers to a specific application, like Spinning Wheel, while a widget is an individual instance of that app you create in your dashboard.
If you’re on a Single App Basic plan (for example, Spinning Wheel Basic), you can create up to 3 Spinning Wheel widgets only.
If you’d like to create multiple widgets for different apps, our All Apps Pack plans are a great option. For example, with the All Apps Basic Pack, you’ll get access to all 98 Elfsight apps for the price of just three — and you’ll be able to create 3 widgets for each app.
Please let me know if this clarifies things or if you have any questions left :slightly_smiling_face:
