Issue description:
Can we increase the height of the PDF we use in the widget?
Issue description:
Hi there, @Shahid_Amin_Khatana ![]()
Unfortunately, there isn’t a way to make it much taller. On desktop, the flipbook is sized so the whole open book stays visible, with some space left for the navigation arrows.
From what I can tell, your document is in landscape format, which is why the flipbook looks like this.
The only workaround we can suggest is slightly scaling up the canvas where the flipbook is rendered. You can do that by adding the following code to the Custom CSS field under the Design tab in your widget settings:
.view canvas {
scale: 120%;
