Eliminate the Excess Space Between Elements in Flipbooks
The borders around the book can look too big, especially the top and bottom ones.
Agreed! Would love to be able to customize the top and bottom margins of the Flipbook. Thanks!
We’d like the Elfsight FlipBook Team to remove all the excess space between the Flipbook’s specified left/right margins, eliminate the excess top and bottom space, and vertical space between the heading, flipbook, and navigation elements as well. This particularly evident in Mobile Viewports—objectionably so.
I agree - the space is much too big.
I would appreciate the CSS codes to change this, if possible.
Hi @Nepal :wave:
Since the flipbook is placed in an iframe, unfortunately, it’s impossible to remove this spacing even with the help of the CSS code :pensive:
If the devs find a solution, we’ll share it here right away!
How to remove the useless paddings and margins around the PDF element? By default the paddings are too large and on mobile it just looks terrible. Please share CSS to overrife paddings and margings before and after Flipbook element.
Welcome to the Community, @Agris_Locs-Darznieks :waving_hand:
Unfortunately, it’s impossible to remove this spacing because the flipbook is placed in iframe.
However, I completely understand your point, agree that it would be great to achieve this. We already have this idea on the Wishlist, and I’ve added your comment there too.
If any news comes up, we’ll promptly update you here :slightly_smiling_face:
And yet, you have other widgets which do not have this problem. It seems like your engineers should be able to solve this…
Hello everyone, and thank you for the Flipbook widget – it’s a great tool!
I’ve successfully embedded it into my homepage, but I’m having an issue with the layout. The gray wrapper around the Flipbook is way too tall and too wide, making the section look oversized on the page.
Is there a way to reduce the height and width of the wrapper so that it fits more neatly and doesn’t take up so much space?
I’ve already tried adjusting the outer container, but it seems the internal wrapper generated by Elfsight controls the dimensions.
Any advice or custom CSS I can apply directly in the widget settings would be very helpful!
Thanks in advance.
Best regards,
Sidi
The thing is that the Flipbook widget has its own peculiarities and is placed in iframe, unlike other widgets
However, we’re hopeful the devs will be able to consider this idea and find a solution to remove this spacing :slightly_smiling_face:
Hi there, @user3524 and welcome to the Community :waving_hand:
Many thanks for sharing your thoughts!
Unfortunately, it’s impossible to reduce the spacing around the flipbook, since it’s a part of iframe.
However, this idea is already on the Wishlist, and I’ve merged your comment with it. If this request gets more votes, we’ll try to consider it in the future updates :slightly_smiling_face:
Adding my vote to find a way to reduce all the margins…
Hi everyone, does anyone know how can I remove the gap between my flipbook pdf view and the bottom menu on my bottom menu on mobile? It looks good on desktop but it adds a lot of padding on mobile.
Thank you in advance!
Hi there and welcome to the Community, @user28627 :waving_hand:
Unfortunately, it’s impossible to remove this gap, since the flipbook is placed inside an iframe. We already have a request for this option on the Wishlist. I’ve moved your comment to the related thread, where we’ll keep you updated :slightly_smiling_face:
Thank you for your reply.
I have several of these flipbooks on my website and all experience the excessive padding/space above/below on sides which makes them look really not professional especially in comparison to competing flipbook tools. This feature initially released quite some time ago, and it appears many people have requested this be escalated from a wishlist item to a more prioritized bug fix, because it really reflects poorly on the quality of the widget if the image is small and eats up valuable scroll space with blank padding. Support - can you please consider escalating this? Otherwise I may have to find another solution for this specific use case.
Same topic. If the problem is solved, I might come back.
Hey there, @Tanya_Alexander, @user13906 :waving_hand:
I completely understand why you’d love to get rif of the excessive spacing and shared your feedback with the dev team. Hopefully, they’ll be able to prioritize this idea as soon as possible.
If any news comes up, we’ll immediately inform you right here :slightly_smiling_face:
Is there a way to control the distance between the flipbook title at the top and controls at the bottom and the actual flipbook itself?
Hi there, @user1359 :waving_hand:
Unfortunately, it’s impossible to remove this space now, since the flipbook is placed inside an iframe. I am really sorry!
We already have a Wishlist request for this feature and I’ve added your comment there too. We’ll update you here if any news comes up :slightly_smiling_face:
