I work with an older demographic and wondering if the flipbook default view can be set to a particular view size? Currently, I need to select the increase magnifyer 2-3 time for a decent view.
Hi there, @Diane_Maidl1 ![]()
Interesing idea! Please let me check with the devs if it’s feasible. I’ll update you once I have their response ![]()
This script will do the trick:
const DEFAULT_SCALE = 1.2;
function listener(selector, callback) {
const firstTarget = document.querySelector(selector);
if (firstTarget) {
return callback(firstTarget);
const observer = new MutationObserver((_, observer) => {
const targetNode = document.querySelector(selector);
if (targetNode) {
observer.disconnect();
callback(targetNode);
listener(
'[class*="flipbook-component__FlipBookEmbed-sc"]',
async (flipbook) => {
const source = flipbook.src;
const response = await fetch(source);
const html = await response.text();
const parser = new DOMParser();
const doc = parser.parseFromString(html, 'text/html');
const base = doc.createElement('base');
base.href = source;
doc.head.prepend(base);
const url = new URL(source);
const fontAwesome = doc.createElement('link');
fontAwesome.rel = 'stylesheet';
fontAwesome.href = `${url.origin}/css/font-awesome.min.css`;
doc.head.prepend(fontAwesome);
const scripts = doc.body.querySelectorAll('script:not([src])');
scripts.forEach((script) => {
if (script.innerHTML.includes('new URL(document.location.href)')) {
script.textContent = script.textContent.replaceAll(
'new URL(document.location.href)',
`new URL("${source}");`
if (script.innerHTML.includes('default: 0.8')) {
script.textContent = script.textContent.replace(
'default: 0.8,',
`default: ${DEFAULT_SCALE},`
'window.devicePixelRatio = 3;' + script.textContent;
if (script.innerHTML.includes('controlsProps: {')) {
'controlsProps: {',
'controlsProps: { \n autoResolution: { enabled: false, coefficient: 3 }, \n'
const parent = flipbook.parentNode;
const newIframe = document.createElement('iframe');
newIframe.src = 'about:blank';
newIframe.style.cssText = flipbook.style.cssText;
newIframe.className = flipbook.className;
parent.replaceChild(newIframe, flipbook);
const iframeDoc = newIframe.contentWindow.document;
requestAnimationFrame(() => {
iframeDoc.open();
iframeDoc.write(doc.documentElement.outerHTML);
iframeDoc.close();
Adjust the Default Scale value in the 1st line of the code and add the resulted script to the Custom JS field on the Settings tab of your widget’s settings:
Note: Custom JS doesn’t function in the preview mode, so you can check the result right on your website.
Test it out and let me know how it works ![]()
Thank you so much, Max. This will work for our project.
Awesome, you’re very welcome ![]()
