Problem with getting Google Reviews
Hi, I have a problem getting our reviews to show in either Google Reviews widget or the All-in-one Reviews widget so I can’t add the widget to our website. Please can you check Google Maps
Hi there @user14833 :wave:
The new reviews don’t appear in the widget right away because of the cache. Our app uses a cache system to make everything load faster and reduce the server load. So the reviews are updated every 72 hours.
If it’s been more than 72 hours and the new review still didn’t appear, just let me know. I’ll be happy to look into this for you :slightly_smiling_face:
Thank you, will do!
Hi Max, reviews still not showing, could you take a look please.
Best regards
Rich
Hi @user14833 :wave:
I see that the reviews are displayed now:
It’s working:-) Did you have to intevene or was it just a matter of waiting longer?
Thanks either way!
Rich
Great! I guess there could be a slight delay, as I haven’t done anything to pull the reviews.
If anything else comes up, we are always here to help :wink:
