Possible to add Atkinson Hyperlegible font?
Developed by the Braille Institute to help low-vision readers. It improves legibility and readability through clear, and distinctive letters and numbers.
Thanks!
Greetings and welcome aboard, @user15475 :wave:
Sure, it’s possible! To apply this font to the widget, the font should be installed on your website.
  1. If Atkinson Hyperlegible is the only font on your website, go to the Appearance tab and choose the Default option for the Font setting:
  1. If you use different fonts on your website, please use this CSS code - Change font for all elements (Event Calendar). Do not forget to add the name of your font there :slightly_smiling_face:
  2. If the Atkinson Hyperlegible font isn’t added to your website, please install it first and then use the CSS code I shared above.
I will try that.
Your tools are impressive, btw;)
Thanks!
Rob Hunter
rob@adilomedia.com
Wow, thanks for your kind feedback!
Really hope these solutions will work for you. But if any difficulties come up, we are always here to help :wink:
