We’ve added an option to enable direct linking to the projects in our Portfolio app ![]()
You can find this setting in the Action on Project Click section on the Project tab of your widget’s settings:
This option allows you to enable/disable adding a hash to the URL when opening a popup. Disabling this setting solves the issue of opening a popup on websites with hash routing.
