CSS for justification of text and Direct Linking in Portfolio widget
  • Issue description: - I am using the Portfolio widget and need to adjust the individual project text (which aligns to the middle) so that it is left justified. I need this for all of my Portfolio projects.
I also have the “Enable Direct Linking to Projects” ticked ON but I don’t know how to find and copy each Project’s direct link.
I would appreciate anyone’s help with these 2 issues. I did check in the Portfolio thread and the CSS thread but was unable to find an answer.
Thanks for your time!
Hi there, @Holley_Jacobs and welcome to the Community :waving_hand:
Do I get it right that you’d like to align all text in the popup to the right?
The issue with the Enable Direct Linking option occurs because of the Wix iframes. To fix it, you should reinstall the widget avoiding iframes -Installing Elfsight widget on Wix avoiding iFrame - Elfsight Help Center
If you face difficulties with the reinstallation, please request our assistance in your dashboard. Our Support Team will gladly help you with it :wink:
Hi Max!!! Thanks for getting back to me. Yes, I would like the text in the pop-up to align to the left - as if you are reading a book.
Thank you for the information about the direct link. Once I reinstall the widget, can you tell me where I would see those direct links?
I appreciate your time and thanks again!!
Got it!
Here is the CSS code to align all text except for the Project Details:
.global-styles,
.eapp-portfolio-project-detailed-component {
 text-align:left!important;
Please add this code to the Custom CSS field on the Style tab of your widget’s settings.
I’ve also asked our devs to provide a code to align the project details. I’ll get back to you on Monday :slightly_smiling_face:
As for the links, when choosing a specific project, a special parameter will be added to your website’s URL, and you’ll be able to copy it from the URL field in your browser.
Thank you so much for the css - that worked perfectly for the project description. But, the title is no longer centered. It doesn’t matter too much, I suppose but if someone has an easy fix like you just provided me, I would like the Title of the Project to be centered.
Have a great weekend!!
Got it! I’ve replaced the previous code with the new one:
.global-styles,
.eapp-portfolio-project-detailed-description {
Hey there, @Holley_Jacobs :waving_hand:
Here is the code to align project details to the left :slightly_smiling_face:
.global-styles,
.eapp-portfolio-project-detailed-meta {
  justify-content: flex-start;
