I would like to have some code made that will permanently change the text color or font color of the “Project Details (Date, Client, etc)” in the Portfolio App. I have updated the code several times myself but it appears that each time Elfsight makes a code change, my code stops working. Thank you in advance.
Hi there, @Chase_Jones ![]()
Sure, here is the CSS code with the static class:
.eapp-portfolio-project-look-card-meta-item {
color: blue;
Please try it out and let me know if it helped ![]()
It worked great! Hoping it’s a permanent solution that will always work even when the code is updated on the backend. Thanks!
Yep, the issue shouldn’t occur anymore ![]()
In the meantime, we’d like to invite you to participate in our new contest, where you can win a 6-month extension for your subscription - May Contest: Create a Caption for Our Photo and Win 6 Months FREE! ![]()
