Popup not working on Wix
I tried installing by inserting the code directly into the page, in the section, but nothing worked. I’m having problems with many Elfsign widgets on Wix. Disappointing…
Hi there, @William_Schepis :waving_hand:
The issue with the display of floating widgets appears because of the Wix iframes. To fix it, the widget should be reinstalled avoiding iframes using one of the methods below:
If you’re still facing difficulties, please request the installation of your widget (do not forget to mention that it should reinstalled avoiding iframes). Our Support Team will gladly assist you with it :slightly_smiling_face:
