Popup layout
Floating popup polls would be a great feature
Hey everyone!
While the floating layout isn’t available for the Poll app yet, we’d like to share a workaround that should work really well.
You can create a Popup widget, add an HTML element to it, and paste the Poll widget’s installation code there. This way, the Poll will appear inside the Popup widget:
