I am having an issue with your popup code interfering with my website animations. Do you have an alternative code to use on my weebly site?
Is there a different option to use the popup on my website?
Hi there, @Sheyla_Adventure_Tra and welcome to the Community
I’ve checked your website, and it seems that you’ve removed the widget. Could you please either add it back or install to the test page? I’ll be happy to check it for you
Hi Max, I just got my website developer to install it back and it’s really messing up the website. You can take a look here: www.sheylaadventure.travel
Thank you so much, @Sheyla_Adventure_Tra
I see that my colleague Pavel helped you resolve the issue in a support ticket. If anything else comes up, we’re always here to help
