Popup: How to make the widget appear by click on a certain element
Want to make your Popup widget subtly appear by click on the element? We have a solution!
That’s really easy, you just need to follow these steps:
Open Settings tab in your widget's configurator and go to Triggers section
Locate your Element ID. To do this, right-click on the required element and select Inspect. Then, find the div id of your element on the Elements tab and copy it
Enable On Click trigger and insert your unique HTML Element ID
GIF 12-5-2023 5-08-27 PM
Faced any difficulties or have questions? Describe your use case in the comments and we’ll gladly help :wink:
I cannot seem to find the DIV ID for another widget’s button. When one popup closes, i want another to open. I just see div classes
Hi @David_Crockett :wave:
Could you please send me a link to the page where your popup is installed and specify the element that should trigger it?
