Pop up review while scrolling
I would like when you visit the website the Google reviews pop up from the bottom right and allow you to exit, but it makes them more visible that on a specific part of the website.
Hi @Garrett_Sagraves
The All-in-One Review or Google Review widget has a floating badge. This should meet your needs. Give it a try.
Here is a screenshot from my website on a desktop computer and it places it where I had the old one, but it looks odd. It does not float to the top when you are on the upper portion of the screen, only in the "section: I have it placed within Wix. Visit elitecprtraining.org to see more of what I am talking about. I thought floating it would scroll with you on the page.
Hey there, @Garrett_Sagraves :wave:
The widget isn’t floating because of the Wix iframes. To fix it, please reinstall the widget avoiding iframes - Installing Elfsight widget on Wix avoiding iFrame - Elfsight Help Center
If you’re facing difficulties with it, please request the installation in your dashboard and our Support Team will gladly assist :slightly_smiling_face:
Thank you. I sent that over to have them add it.
Just following up to see if there is any idea when the floating badge may be completed?
Thank you,
Hi @Garrett_Sagraves :wave:
I see that my colleague Alina has just reached out to you and will assist you with the installation :slightly_smiling_face:
