Percentages don't calculate correctly
Hello,
When creating a field and choosing percentage, the calculator still sees the input into that field as a number, not a percentage. For example, when I input 50%, the calculator uses that as 50 in my formulas instead of 0.5. All of my results are greatly inflated due to this mathematical error. Am I doing something incorrectly with the fields? Thanks for any help.
Hi there, @Lara_Morris :wave:
I’ve passed it on to the dev team and will update you once any news comes up :slightly_smiling_face:
Thanks Max. Any ETA would be helpful since this affects the usability of the product. Calculations are inaccurate as it functions currently. Thank you,
It’s hard to share the ETA, but we’ll try to resolve it as soon as possible. I’ll keep you updated!
In the meantime, there’s a temporary workaround you can use. Let me explain using the example of the Accident Rate Pre-Training field.
You’ll need to create the following calculation:
Once that’s done, replace the Accident Rate Pre-Training field in all calculations where it’s used with the new one (Accident Rate Pre-Training 2):
You should follow the same steps for any other fields using the percentage format.
Please try it out and let me know if it helped :slightly_smiling_face:
Thank you very much for the solution!
Hi @Lara_Morris :wave:
I’ve checked with the dev team, and they’ve confirmed that the behavior you’re seeing is correct. The Format setting affects how the value is displayed in the field, but it doesn’t impact the calculation itself.
I hope that clears things up!
So, to convert percentages into numbers, you can either keep using the previous solution or simply divide the value by 100 in the calculation :slightly_smiling_face:
