Our Chatbot needs at least 2 minutes to give a answer
  • Issue description: Our Chatbot needs at least 2 minutes to give an answer. On the confirmation email, most of the time there is not shown any answer given to the costumers. Is it an Elfsight problem?
  • Link to the page with the widget in question: UCI MTB World Cup Lenzerheide | 19.–21. September 2025
Hi there and welcome to the Community, @Mara_Petrillo :waving_hand:
I am so sorry about all the inconvenience!
Unfortunately, there are some technical issues on the side of Open AI, which affected our widgets as well. We keep tabs on the situation and will update you as soon as it’s fixed.
In the meantime, you can also check the issue status here - https://status.openai.com/
Everything should be back to normal!
Please check your widget and let me know how it works :wink:
Yes it is, thank you!
Awesome, you’re welcome :wink:
