Option to pin comments at the top
Please add an option to pin comments at the top
I would like to suggest a feature that could enhance the user experience for comment sections. It would be very useful if the owner of a page or widget could pin one of their comments so that it always appears as the first comment.
This would be especially valuable in situations where the first comment is used to post a question or discussion prompt, encouraging visitors to respond in the comments. Having the ability to pin such comments would help ensure they remain visible and engaging, regardless of how many other comments are posted afterwards.
If it is possible to achieve this through a code snippet or custom configuration, please let me know how this could be done.
Thank you for considering this suggestion, and I hope this feature could be added in a future update.
Hi there, @user31758 :waving_hand:
I am glad to say that this idea is already on the Wishlist! I’ve merged your comment with the existing request, where we’ll keep tabs on the feature popularity :slightly_smiling_face:
I agree, this would be so useful!
Great :+1:.
It would be ideal if Elfsight had an app, since certain widgets, like the comments widget, could be managed from the móvil app without having to log in from a computer. Mobile accessibility would be fantastic. Maybe in the future
Thanks!
Do you mean to edit your widget on mobile? If so, you can just log in to your Elfsight dashboard on mobile and make the adjustments there :slightly_smiling_face:
