On / Off for Mobile Devices
I think there should be an ON / OFF button / toggle for mobile devices for the slideshow since site speed is affected by load times. Having the ability to turn the slideshow off from displaying on mobile could really help!
Hi @Aviad_Stark :wave:
Thanks for adding your idea to the Wishlist!
We’ll try to consider this opportunity in the future. As a workaround, you can try to install widgets only for the desktop version - How to install widget only for dektop website version.
Feel free to check it out :wink:
