Maintain Slideshow Aspect Ratio
There should be an ability to maintain the slideshow’s AS-IS aspect ratio or to designate the display aspect ration because the slideshow and text look kind of wonky by default on mobile devices.
Many thanks for sharing your idea with us!
Could you please specify what exactly you’d like to change in the slide appearance? Do you want to remove some padding, place text differently, or anything else (a screenshot would be really helpful)?
We’ll be happy to check if there is a custom solution for your case :slightly_smiling_face:
