Hi ElfSite Team,
I’m reaching out to suggest a new feature for your platform: a media carousel that allows slides before and after the currently focused slide to be partially visible. This design would give users a sneak peek of the next and previous slides, creating a more dynamic and interactive experience. Ideally, these partially visible slides would appear as if they’re seamlessly sliding into the sides of the screen, enhancing the visual appeal and intuitiveness of navigating through content.
This feature could significantly improve user engagement by hinting at more content just a swipe or click away, encouraging more interaction with the carousel. It would be great for both desktop and mobile views, adapting responsively to ensure a consistent user experience across all devices.
Best regards,
Ahrue
