Recently I created an account on "https://elfsight.com/’ this website to fetch an Instagram feed
The free plan only has 200 views if it exceeds 200 views what will happen? The widget script does not work
Let me know
Thank You
Let me know
Thank You
Happy to see you here @Priyanka_Chikkatumba ![]()
When your views limit is over, the widget on your website will be deactivated. So the widget will not be visible to your website visitors until next reset date.
Before your views limit runs out, you will get several notification emails from Elfsight Apps, so deactivation won’t come as a surprise.
When the deactivation happens, you can either:
wait for your next views reset date - the views are reset every month
Just in case, here’s an article that will explain the views metric in greater detail - Views: everything you need to know.
