Need a widget that is more mobile friendly
Widget doesn’t show up on mobile well.
Hi there and welcome to the Community, @Josh_Lawson :waving_hand:
As far as I understood, your widget is installed on the Wix website. The display issues might occur because of the Wix iframes. To fix it, the widget should be installed avoiding iframes - Installing Elfsight widget on Wix avoiding iFrame via Custom Code - Elfsight Help Center.
If you need assistance with the reinstallation of the widget, please request it in your dashboard. Our Support Team will be happy to help :wink:
