N8n integration
would be useful if we could connect this to n8n or if you could create n8n node integration with n8n.
Greetings and welcome to the Community, @greg_t :waving_hand:
Thanks for the idea! If this request gets more votes, we’ll try to consider N8n integration in the future updates :slightly_smiling_face:
As for the Webhooks integration, we have a separate request for this. Feel free to upvote it - Allow external webhook calls
It would be very useful to explore the possibility of integrating the Elfsight AI Agent with n8n, allowing specific situations, events, or conditions detected by the agent to trigger an n8n workflow.
The idea is to enable the AI Agent to do more than just respond to users. When a specific situation occurs, the agent could automatically trigger an external automation workflow.
From a technical perspective, we would need to explore the best implementation approach. One possibility could be a configurable webhook/event trigger within Elfsight that sends relevant event or conversation data to an n8n webhook.
This could open up many automation possibilities, such as sending emails, creating CRM records, notifying team members, generating tasks, updating databases, or connecting with other external services.
The main requirement would therefore be to provide the AI Agent with a mechanism to trigger events in n8n based on specific conditions or actions that occur during a conversation.
It would also be worth defining which events should be supported initially and what information should be included in the payload sent to the n8n workflow.
Hello there, @Francisco_Javier_Ma1 :waving_hand:
Thank you so much for such a detailed comment!
This is a great idea, we’ll keep it in mind and see for more comments from other users :slightly_smiling_face:
Hey everyone!
The n8n integration is already live :tada:
Find more details in this post: AI Chatbot: Send chat info to Zoho CRM, Pipedrive, n8n, and Pabbly Connect! 🚀
