Allow external webhook calls
Ideally, if you simply have a chatbot that allows for external webhook calls, we could integrate it with Zapier, Make, n8n, etc.. more versitile
Hi there, @Rafael_Alencar :wave:
Great idea, thanks for sharing! If more users upvote this request, it might be considered in the future :slightly_smiling_face:
in the meantime, you can use WhatsApp widget and setup the same number to be create automations with n8n
Please add a section that we can add in webhooks to the chat agents. Thank you!!
Hello there, @Thomas_Schalch1 :waving_hand:
Glad to say that this idea is already on the Wishlist! I’ve added your comment to the existing request, where we’ll keep you updated.
Many thanks for the feedback and yes, welcome to the Community :wink:
Hello guys :slight_smile:
Thanks a lot for your suggestion! We’d love to better understand your use case.
Are you looking to:
• send user data from the Chatbot to external tools like Zapier, Make, etc.
• or use data from external services (via webhooks) to generate chatbot replies?
Or maybe both?
It would be great if you could share a bit more about what you’re trying to achieve.
Webhook integration
Hey there and welocome to the Community, @Lucas_Roberto :waving_hand:
Thank you for the feedback!
We already have this idea on the Wishlist. I’ve merged your comment with the existing request, where we’ll keep you updated :slightly_smiling_face:
Hey everyone!
Great news - the Webhook integration is already live :tada:
Find more details in this post: AI Chatbot: Zapier, Google Sheets and Webhook integrations are available now 🚀
