Multiple Choice Entry Limits
When creating a multiple choice option there is not minimum or maximum required field. This means that if you have a (select up X) the form doesnt stop people form selecting more than that. or require a minimum of 3 items if that is also preferred.
In the case of a food order form, “What deli meats (up to 3) would you like on your sandwich?”
In the case of a survery for information, “What are your top 3 favorite products?”
This feels like a major fault for it not already being present in the form builder. Hope it gets added quick.
Hi there, @N_G :wave:
This is a great idea, I really like it! Let’s see what other users think about it :slightly_smiling_face:
Thanks Max, hope it gets some upvotes. Wanted to build a form to use, but that limitation might send me elsewhere, least until it gets added. How many is usually needed for an idea to be implemented?
Hi @N_G :wave:
We prioritize ideas based on 2 factors: complexity of implementation and number of votes. At the moment, we have a bunch of requests with the higher priority and our devs are focused on them.
So, I am afraid, this feature won’t be released in the near future, but if more users upvote it, it might be prioritized sooner.
If anything changes, we’ll update you here right away :slightly_smiling_face:
I want to be able to give 15 or more choices on check boxes but people to have the right to select only 3 choices or a specific number of choices. :blush:
Hi there @Sissi1 :wave:
Many thanks for sharing your thoughts!
We already have such a request on the Wishlist. I’ve moved your comment to the related thread, where we’ll keep you in the loop :slightly_smiling_face:
